通信機器
Type of machining center
[Vertical]
A machining center with a vertical spindle on which tools are mounted and rotated.
It is not suitable for mass production because it does not discharge chips well.
It is compact and widely used in the processing of molds and the like.
[Horizontal type]
A machining center with a horizontal spindle that rotates with tools attached.
Good chip evacuation, material supply and product transport pallet charger
Since it can be installed, it is suitable for mass production.
[gate type]
When viewed from the front, the structure that supports the spindle is shaped like a gate.
Because it can be made large in the front and depth direction of the table, it is suitable for processing heavy and large objects.
I'm on my way.
[5-axis control]
Machining centers generally have three axes: the X, Y, and Z axes.
In other words, the main axis of rotation moves in the vertical Z-axis direction when viewed from the front.
In addition, the table on which the workpiece is fixed moves in the front/rear Y-axis direction and the left/right X-axis.
In 5-axis control, the table rotates on the C-axis and tilts on the B-axis.
With the addition of the C-axis and B-axis, more complex shape machining is now possible.
Let's contact us if you have any inquiry regarding trial,small lot,masproduction,
whatever!
❐❐❐________________________________
Endo Co.,Ltd. Sales Department
NISHIJIMA Shin
Mobile:+818071657830
Email : shin-nishijima@endo-m.com
Facebook :www.facebook.com/EndoFactory
_________________________________❐❐❐
株式会社 遠藤製作所 (えんどうせいさくしょ) |
エミダス会員番号 | 72643 |
日本 山形県 山形市 |
電話番号 | 023-685-5015 | FAX番号 | 023-685-5016 |
資本金 | 7,000 万円 | 年間売上高 | 150,000 万円 |
社員数 | 76人 | 担当者 | 西嶌 新 |
産業分類 | 産業用機械 / OA機器 / 医療機器 | ||
