通信機器
1. What is a machining center? マシニングセンタとは
The Japan Machine Tool Builders' Association defines a machining center as follows.
“We perform a wide variety of processing such as boring, milling, drilling, tapping, and reaming.
NC machine tool that can be performed continuously
A major feature of the machining center is that it can perform the various types of machining described above.
It is "Automatic Tool Changer (ATC)".
In addition to this ATC, by setting the machining program in the NC unit,
You can proceed from tool switching to machining without human intervention.
Depending on the configuration of the machine, there are horizontal, vertical, gantry, etc. In recent years, more complex shapes
"5-axis control machining centers" that can process are becoming popular.
2. What is the difference between a milling machine and a lathe?
❑Difference from milling machine
A machine similar to a machining center is a milling machine.
The difference is whether or not the "ATC device" is attached.
Since only one tool is attached to a general milling machine or NC milling machine,
Change tools when performing another operation (e.g. from milling to reaming).
must be done by a person.
Equipped with NC and ATC devices, tools can be automatically changed,
It can be said that not only productivity and machining accuracy but also safety has been greatly improved.
❑Difference from lathe
Machining centers and milling machines "fix the material and cut it by applying a rotating tool"
whereas
A lathe has a big difference in that it "turns the material and cuts it with a fixed tool".
Because of this difference, machining centers are good at processing square objects.
It can be said that lathes are good at processing round objects.
Also, a machine that combines a lathe and a machining center is called a multitasking machine.
A single machine can complete multiple processes.
Let's contact us if you have any inquiry regarding trial,small lot,masproduction,
whatever!
❐❐❐________________________________
Endo Co.,Ltd. Sales Department
NISHIJIMA Shin
Mobile:+818071657830
Email : shin-nishijima@endo-m.com
Facebook :www.facebook.com/EndoFactory
_________________________________❐❐❐
株式会社 遠藤製作所 (えんどうせいさくしょ) |
エミダス会員番号 | 72643 |
日本 山形県 山形市 |
電話番号 | 023-685-5015 | FAX番号 | 023-685-5016 |
資本金 | 7,000 万円 | 年間売上高 | 150,000 万円 |
社員数 | 76人 | 担当者 | 西嶌 新 |
産業分類 | 産業用機械 / OA機器 / 医療機器 | ||
