食品機械
Tfe-Lok is a PTFE-impregnated hard chrome plating.
Self-lubricating chrome plating Tfe-Lok is an incomparable high-functionality composite surface treatment technique that provides excellent mechanical properties (such as high rigidity and wear resistance) of hard chrome plating, and non-adhesiveness and excellent mold releasability of polytetrafluoroethylene (PTFE).
For applications where Teflon coating lacks durability, or where chrome plating lacks slipperiness or mold release properties, Tfe-Lok is the optimal solution!
[Features]
1. Hardness
The chrome-plated base provides a hardness of approximately Hv850.
2. Heat Resistance
Continuous use up to around 250°C.
Up to 300°C, “Tfe-Lok α,” is also available.
3. Processing Characteristics
The low processing temperature of approximately 200°C minimizes thermal impact on the base material.
About Tfe-Lok
https://www.otec-kk.co.jp/english/surface/02.html
[Original Surface Treatments]
“Chroamor”– Ultra-Hard Chrome Plating
Unlike conventional chrome plating, Chroamor has no cracks and can be hardened up to HV 1800 through heat treatment between 200 and 600°C.
https://www.otec-kk.co.jp/english/surface/03.html
“Hybrid Chrome Plating” – Superior Corrosion Resistance Beyond Ni-Cr Plating
In this treatment, a glass-based inorganic material is impregnated into the cracks of the hard chrome plating. This compensates for the weak points of hard chrome plating and significantly improves corrosion resistance
Otec Co., Ltd.
3-1-40 Imafukuhigashi, Joto-ku, Osaka City, Osaka Prefecture
536-0002 Japan
Tel: 81-6-6939-4591
Fax: 81-6-6939-1503
Website: https://www.otec-kk.co.jp/english/
Technical site: https://otec-kk.info/
Blog: https://blog.otec-kk.co.jp/
オテック 株式会社 (おてっく) |
エミダス会員番号 | 22467 |
日本 大阪府 大阪市城東区 |
| 社員数 | 55人 | 担当者 | 岩田 一希 |
