Tfe-Lok is the ideal solution for applications where PTFE coatings lack durability, and where chrome plating alone does not provide sufficient lubricity or release properties.
Unlike conventional coatings, Tfe-Lok impregnates fluoropolymer into the microcracks of hard chrome plating.
The base chrome plating supports the load, while the fluoropolymer is protected from wear.
【Features】
1. Hardness
The base layer is hard chrome plating, providing a hardness of approximately HV850.
2. Heat Resistance
Recommended for continuous use up to 250°C
A high heat-resistant model, “Tfe-Lok α,” is also available for use up to 300°C.
3. Safety
This surface treatment complies with PFOA regulations.
4. Processing Characteristics
The treatment temperature is as low as approximately 200°C, which means that there is almost no thermal influence on materials.
Tfe-Lok has been widely adopted for applications such as guide components and heat sealers.
https://www.otec-kk.co.jp/english/surface/02.html
Otec Co., Ltd. is a specialist in hard chrome plating, with over 60 years of history.
We provide fully integrated production — from roll manufacturing, plating, to finishing.
Otec Co., Ltd.
3-1-40 Imafukuhigashi, Joto-ku, Osaka City, Osaka Prefecture
536-0002 Japan
Tel :81-6-6939-4591 ・ Fax :81-6-6939-1503
Website: https://www.otec-kk.co.jp/english/
Technical site: https://otec-kk.info/
Blog: https://blog.otec-kk.co.jp/
オテック 株式会社 (おてっく) |
エミダス会員番号 | 22467 |
日本 大阪府 大阪市城東区 |
| 社員数 | 55人 | 担当者 | 岩田 一希 |
