工業用材料
PEM
PEM® self-clinching studs are installed by placing them in properly sized holes in the sheets and squeezing into place with any standard press. The squeezing action embeds the head of the stud into the sheet. The metal displaced by the head flows smoothly and evenly around the ribs and into the annular groove – creating a flushhead assembly and securely locking the stud into the sheet with high torque-out and pushout resistances.
- FH (flush-head) studs are available in aluminum, steel, or stainless steel. They are also available unthreaded on special order.
Flush-head in designated minimum sheet thickness or greater.
- Type FH is recommended for use in steel or aluminum sheets HRB (Rockwell “B” scale) 80 or less and HB (Hardness Brinell) 150 or less.
- Type FHS is recommended for use in steel or aluminum sheets HRB (Rockwell “B” scale) 70 or less and HB (Hardness Brinell) 125 or less.
- Type FHA is recommended for use in aluminum sheets HRB (Rockwell “B” scale) 50 or less and HB (Hardness Brinell) 82 or less.
ND VIET NAM INDUSTRY JOINT STOCK COMPANY (ベトナムサンギョウカブシキガイシャ) |
エミダス会員番号 | 95373 |
国 | ベトナム | 住所 |
ベトナム バクニン Tu Son |
電話番号 | +84-988-392-495 | FAX番号 | +84-988-392-495 |
資本金 | 1,300,000 USD | 年間売上高 | |
社員数 | 20人 | 担当者 | Hoang Thuy Hang |
産業分類 | 建築土木資材 | ||
