工業用材料
PEM
Self-clinching nuts are installed by placing them in properly sized holes in sheets and applying a parallel squeezing force to the head of the nut. The sheet metal surrounding the head cold flows into an undercut thereby making the fastener an integral part of the sheet. A serrated clinching ring prevents the fastener from rotating after installation.
Provide load-bearing threads in thin sheets with high pushout and torque-out resistance.
Type CLA is recommended for use in steel or aluminum sheets HRB (Rockwell "B" scale) 50 or less and HB (Hardness Brinell) 82 or less.
Types CLS / CLSS are recommended for use in steel or aluminum sheets HRB (Rockwell "B" scale) 70 or less and HB (Hardness Brinell) 125 or less.
Types S / SS are recommended for use in steel or aluminum sheets HRB (Rockwell "B" scale) 80 or less and HB (Hardness Brinell) 150 or less.
Type SP is recommended for use in stainless steel sheets HRB (Rockwell "B" scale) 90 or less and HB (Hardness Brinell) 185 or less.
Eg: CLS-M3-2
Thread Size x Pitch: M3 x 0.5
Thread Code: M3
Shank Code:2
A (Shank) Max.:1.38 mm
Rec. Min. Sheet Thickness:1.4 mm
Hole Size in Sheet + 0.08: 4.22 mm
C Max.: 4.2 mm
E ± 0.25: 6.35 mm
T ± 0.25: 1.5 mm
Min. Dist. Hole C/L to Edge: 4.8 mm
For Use in Sheet Hardness: HRB 70 / HB 125 or Less
Thread Specification: Internal, ASME B1.13M, 6H
Fastener Material: 300 Series Stainless Steel
Standard Finish: Passivated and/or tested per ASTM A380
ND VIET NAM INDUSTRY JOINT STOCK COMPANY (ベトナムサンギョウカブシキガイシャ) |
エミダス会員番号 | 95373 |
国 | ベトナム | 住所 |
ベトナム バクニン Tu Son |
電話番号 | +84-988-392-495 | FAX番号 | +84-988-392-495 |
資本金 | 1,300,000 USD | 年間売上高 | |
社員数 | 20人 | 担当者 | Hoang Thuy Hang |
産業分類 | 建築土木資材 | ||
