弱電・家電
測定機械
【The Best Choice for Water Applications!】
For sealing materials used in water supply systems—such as O-rings and rubber gaskets—EPDM (Ethylene Propylene Diene Monomer) is widely used.
However, when EPDM is used in water supply applications, long-term exposure to water pressure can cause the rubber to deteriorate or deform over time. This gradual strain may eventually lead to water leakage.
In addition, residual chlorine in tap water can react with additives contained in the rubber, causing the carbon black (a reinforcing agent) to leach out. This results in what is known as the “ink phenomenon” (carbon elution), which can appear as black particles or cloudiness in the water.
To address these issues, we developed a chlorine-resistant EPDM rubber material optimized specifically for water supply use — E-756A.
【Material Name】
E-756A (Chlorine-Resistant EPDM for Water Applications)
【Material Properties】
Base Polymer: EPDM
Hardness: 70
This material offers excellent compression set resistance and high chlorine resistance, making it an outstanding choice for rubber sealing materials in water-related applications.
It’s one of our most highly recommended rubber compounds.
This material is used in various household fixtures, such as kitchens, bathrooms, washrooms, and toilets.
We handle not only standard O-rings (P-type, G-type, etc.) but also non-standard sizes and custom-shaped gaskets.
From prototyping to mass production, we offer full, one-stop support.
If you have any issues or concerns related to rubber products, please don’t hesitate to contact us.
We’ll carefully listen to your needs and provide tailored solutions.
【Serious About the Small Details】
Takaishi Industry Co., Ltd.
Website: https://takaishi-ind.co.jp/
Keywords: Rubber, O-ring, Gasket, Seal, Water Supply, Toilet, Shower, Kitchen, Chlorine Resistance
高石工業株式会社 (たかいしこうぎょう) |
エミダス会員番号 | 73335 |
日本 大阪府 茨木市 |
| 資本金 | 年間売上高 | ||
| 社員数 | 85人 | 担当者 | 高石 秀之 |
