弱電・家電
測定機械
Have you ever separated a rubber packing after a long time and thought,
"It’s stiffer than I expected"?
(for example: lever mechanisms, cartridge replacement parts, or other areas where torque is applied)
Many people tend to accept it as “just the way rubber is,”
but the solution to this problem is “SP Rubber.”
Our uniquely developed SP Rubber reduces sliding resistance by approximately 70% compared to conventional products (company data).
It enables smooth operation and greatly improves usability.
However, there are certain conditions to achieve its maximum performance.
In some cases:
“It’s hard to see an effect with this usage,” or
“A slight modification could make it move even more smoothly.”
So please feel free to contact us.
We provide the most suitable proposals that fit to your usage and environment.
If rubber resistance is causing problems, don’t hesitate to leave it to us.
高石工業株式会社 (たかいしこうぎょう) |
エミダス会員番号 | 73335 |
日本 大阪府 茨木市 |
| 資本金 | 年間売上高 | ||
| 社員数 | 85人 | 担当者 | 高石 秀之 |
