弱電・家電
測定機械
[Takaishi Industry's Prototyping Features]
1. Short time Completion
We use aluminum molds designed and manufactured in-sourcing, ensuring short time completion.
Machining Centers are equipped in Takaishi Industry for short time simple molds completion used for prototyping.
https://takaishi-ind.co.jp/business/prototype/
2. Molded Products with the Same Quality as Massive Production
We create prototypes using molds with the same accuracy and materials as massive production.
The prototypes can be used in various evaluation tests.
[Why we recommend Mold Prototyping]
While cutting processes can be used for rubber prototyping, Takaishi Industry recommends molding prototypes using molds.
By evaluating the molded prototypes, we reduce the gap between the prototype and massive production in terms of materials and finish.
This helps prevent situations like:
"The prototype worked well, but it didn’t perform as expected in massive products."
Proposing from choosing material to shaping,
As the role of seal manufacturer, we use the know-how gained to solve your challenges.
[Materials that we handle]
NBR (Nitrile Rubber), EPDM (Ethylene Propylene Diene Monomer), FKM (Fluorocarbon Rubber)
[For contact]
https://takaishi-ind.co.jp/contact/
[Rubber Prototyping, Short Time Completion, Evaluation Tests, Research, Design, Development]
高石工業株式会社 (たかいしこうぎょう) |
エミダス会員番号 | 73335 |
日本 大阪府 茨木市 |
| 資本金 | 年間売上高 | ||
| 社員数 | 85人 | 担当者 | 高石 秀之 |
