時計・眼鏡・宝飾品
Leave all the interior fittings, cases, and everything to us!
The Sanpelca series has different numbers based on density (specific gravity), with L-1400 (14 times) < L-2500 (25 times expansion) < L-3000 (30 times), meaning that smaller numbers indicate higher density and firmness, while larger numbers indicate lower density and softness. It is possible to cut the material into shapes that fit the case and contents, as shown in the photo.
Additionally, we can also accommodate orders for the outer case itself, so please leave the entire case to us.
Uses: Packaging materials and cushioning for home appliances, precision equipment, glass, etc. Industrial materials such as packing and spacers. Cushioning sheets, mats, and underlays for work tables.
Sanpelka L-2500 is a type of closed-cell polyethylene foam (expanded polyethylene sheet) manufactured by Sanwa Chemical Industry Co., Ltd.
Structure: Closed-cell (each bubble is sealed)
Density (specific gravity): Approximately 0.025 g/cm³ (25 times expansion)
編集担当 加藤 お問い合わせお待ちしております!
株式会社 フジカ工業 (ふじかこうぎょう) |
エミダス会員番号 | 72493 |
日本 埼玉県 川口市 |
| 資本金 | 3,000 万円 | 年間売上高 | |
| 社員数 | 23人 | 担当者 | 営業部 |
