Otec Co., Ltd. is a specialist in hard chrome plating, with over 60 years of history.
We provide fully integrated production — from roll manufacturing, plating, to finishing.
[Precision grinding]
We grind high-precision coating rolls, casting rolls, and other rolls that are used in optical, battery, and other manufacturing industries.
・Roll finishing up to a maximum precision level of 1/1,000 mm. (The level of precision differs according to the size and shape of rolls.)
・Ensuring surface smoothness as well as precision.
・Grinding rolls with bearings mounted.
・Handling a variety of crowning (such as radial crowning and tapered crowning)
[Mirror finishing]
Our ultra-mirror finishing has been used for a large number of casting rolls, polishing rolls, cooling rolls, heating rolls, stretching rolls, precision coating rolls, and rolling rolls for forming films and sheets that attach greater importance to transparency.
・Up to a level of an ultra-mirror finish with a surface roughness of Rmax 0.05S or lower.
・Mirror finishing that removed fine grinding marks that cannot be detected with a surface roughness tester.
[Original Surface Treatments]
“Chroamor”– Ultra-Hard Chrome Plating
Unlike conventional chrome plating, Chroamor has no cracks and can be hardened up to HV 1800 through heat treatment between 200 and 600°C.
https://www.otec-kk.co.jp/english/surface/03.html
“Tfe-Lok“– High Durability, non stick & Low Friction
A hard chrome plating impregnated with fluororesin. For customers who aren’t satisfied with conventional fluororesin coatings.
https://www.otec-kk.co.jp/english/surface/02.html
“Hybrid Chrome Plating” – Superior Corrosion Resistance Beyond Ni-Cr Plating
In this treatment, a glass-based inorganic material is impregnated into the cracks of the hard chrome plating. This compensates for the weak points of hard chrome plating and significantly improves corrosion resistance
Otec Co., Ltd.
3-1-40 Imafukuhigashi, Joto-ku, Osaka City, Osaka Prefecture
536-0002 Japan
Tel :81-6-6939-4591 ・ Fax :81-6-6939-1503
Website: https://www.otec-kk.co.jp/english/
Technical site: https://otec-kk.info/
Blog: https://blog.otec-kk.co.jp/
オテック 株式会社 (おてっく) |
エミダス会員番号 | 22467 |
日本 大阪府 大阪市城東区 |
| 社員数 | 55人 | 担当者 | 岩田 一希 |
