造船
航空機
道路
This product is a dedicated salt cleaning device that cleans salt adhering to aircraft, vehicles, ships, steel bridges and other steel structures with low-pressure jet water flow containing micro-bubbles, and prevents salt damage corrosion. It has the following features.
1) Long-distance injection
The micro-bubble mist jet with an effective injection length of 10 m or more enables safe and efficient cleaning work in high places and long-distance areas.
the object to be cleaned.
2) Low pressure cleaning
Since the injection pressure is the same as the pneumatic pressure (standard pressure: 0.6 to 0.7Mpa) of the drive source of this device, the object to be cleaned will not be damaged.
アキモク鉄工株式会社 (あきもくてっこうかぶしきかいしゃ) |
エミダス会員番号 | 71654 |
日本 秋田県 能代市 |
資本金 | 3,000 万円 | 年間売上高 | 50,000 万円 |
社員数 | 33人 | 担当者 | 花下智之 |
産業分類 | 産業用機械 |
